I'm sure they'd let me keep it there for awhile but not in the pole shed.
Here's a list of the bigger stuff I have. The tractor is the oldest but a very desirable model. I also have various 3pt. hitch implements, some like new and a 94/95 Yamaha Big Bear 350 quad and trailer.
1965 ** 135UK. 3 cyl. Perkins diesel with working 12 speed multi-power trans., loader with blade and bucket and cab off an MF20 industrial tractor, very good rear tires, chains, 5000hrs.
1986 Cat 931B track loader with factory quick attach backhoe, 4 in 1 loader bucket with teeth and bolt on edges, approx. 1500 hours on new undercarriage, rebuilt engine with 3 ring IPD pistons, rebuilt steering clutches and brakes, 5800 hours.
1986 Champion 730A grader with ripper, like new rear radial foam filled tires, 16' moldboard (2' extension was welded on), new serrated blades, Cummins 8.3, new seat. Hours unknown but starts and runs excellent.
1994 Thomas T133 skid steer loader, Kubota V1902B, comparable to Bobcat 743/753, built in Canada, both drive motors replaced, new glow plugs, like new tires, 3 good buckets (smooth, tooth and snow), 1 bucket needing rebuilt, 4500hrs. Most service records, original owner, runs like new.
1994 Ford L9000 dump truck, Cummins M11, 9 speed trans., heavy spec. with 16K front axle and 40K Hendricksen walking beam rears, double frame with minimal rust and no rust jacking, dual steering boxes, 15' box with air trip gate, replacement speedometer, new steer tires, good rears except 1 has a patch.
1995 GMC Topkick with 16' grain box and hoist, 6.0L gas engine. Good tires, runs great with under 200,000 kms., used as a water truck with or without 2000 gallon poly water tank, box is rough.
