Shimmy1
I'm thinking about getting blasted tonight, just to celebrate. Maybe I'll just chase the wife around.
Either way, I'm celebrating.
Smart ass. Did I let you down? You were hoping for 10 pages of misery? Lol
Story on that, I'm sure someone will ask. It was purchased new by our department in 1977. We upgraded it, and tried to sell it, but couldn't get a bid. The guy I work with and myself each decided to spend $2500 and buy it, he will use it during harvest, I will when I'm burning trees.I was hoping it would get bad enough, that you would need that fire truck in the corner. But I'll live with the disappointment.![]()
I've asked the mods if they could edit the thread title to include "Rebuilding Deere 1810E scraper"
Done.
And for the record I would have traded that pan in on a new one. With all the money you're making, I'm sure you needed a write off.![]()
These pins are FIXED in these bores. They never turn, are never greased. The rotation happens between the pin and cylinder rod eye, the bushes have enough wear to justify replacement, minimal wear on the pin even. Cylinders need resealing. But since I'm putting new bushings in, they are getting pins.Getting the pins turning will help in getting them out. The pins have a specific section that takes the highest force from the cylinder. It would only take a slight deflection for the pin to be basically locked in position. Turning them out of their locked/set position should let them come out easier. In a perfect world pins would slide in and out easily but that 1 time you ran out of grease and had to go a little longer without grease or grease wasn't getting all around the pin is all it takes. That's why auto lube is great where it's practical.
Are you hinting that I am not going to want to do a bunch of work to those bores before putting new pins in? I was planning on honing the bores out good and clean, greasing them well, and possibly plan on pulling them every winter to keep them semi-free? Something is telling me that I prob shouldn't do this....The way those pins are cantilevered they have to be very tight in the bores. If they start to work they will fail quickly.
This ram uses a separate air-operated pump, so it's basically being used as a porta-power. This only has a 2" stroke, but for a situation like I'm using it, that would probably be enough.AME Intl sell all Chinese products. If you're happy enough to buy and use Harbor Freight tools, then by all means, purchase the AMT 100T jack.
I've got one of the Chinese hyd bead breakers, identical to the AMT unit, it works just fine for my occasional use, but I wouldn't buy one to use for making a living out of tire repair work.
If you want a 100T jack with real quality, then you buy a U.S. made brand-name product - Enerpac or OTC.
You can easily acquire parts for the U.S.-made equipment, but with the Chinese product, you're on your own when it starts to leak, or something breaks on it.
Just keep in mind also, that hyd jacks are built to operate standing vertically, and if you lay them down, you need to keep the pump on the bottom side.
