Please excuse what is likely a stupid question from someone that should likely know better.
Despite owning a 2006 Case 580 Super M Series 2 for 6 years I’m still a complete idiot when it comes to mechanical fixes. So with that admission out of the way……
I had the 580 parked nose down on a steep hill. The low fuel light wasn’t on until I was on the hill. I managed to start the machine and back up onto the level where it then died. I suspect a bit of air got in the fuel line so it now doesn’t start. (It could be something else but I thought I’d start with trying to bleed the system). I managed to tow it so it’s not blocking the driveway at the moment.
Can anyone give me step by step instructions on how to bleed the fuel line? I put in 10 gallons of diesel. I know where the fuel water separator is. I can see the small pump behind and below it. I’m guessing this is the primer pump. I have pumped it but it didn’t do anything. I can follow the fuel lines to the injectors.
Do I loosen the fuel lines at the injectors and prime from there.
Apologies for such a basic question but any help would be appreciated.
