Russ T Shackleford
In trying to service my komatsu pc50uu-1 final drive. It started to feel weak on the one side and then abruptly stopped working.
I sourced a complete final drive for around $2k but would like to just replace the drive shaft if that's all that's destroyed in there. The oil was very glittery... so I know something is ground to a nub in there.
I pulled the snap ring from the face plate but can't get the plate to pop off. I put longer pipe plugs in there to see if I could remove the plate by rotating or prying it but no luck.
I will try a slide hammer tomorrow. I don't believe there is an internal ring like the kyb drives. This is a hydash brand.
Landamachinery.com lists the individual parts I would need to rebuild the drive. Let me know if you've found better websites for pc50 parts. Thanks!
