I've got a 90's Skyjack SJ-6826 rough-terrain scissor lift that has suddenly started giving me problems with the platform controls. The joystick will engage the electric motor, I can see and hear it spinning, but it does not work the hydraulics at all - expect for the 'lowering' function; when I use the ground control switch to raise the platform (works with no issue, raises quickly and sounds strong), the joystick will still engage the lowering function, but anything else just spins the electric motor.
I've tried plugging the joystick controls into the lower connector to remove a pretty significant length of harness wiring from the picture, and no change. Any thoughts?
