Oil grades. Can I adjust the OEM requirements to make bulk oil purchase a reality?
Cogniz
Dayton,tn
Good morning, y'all.
I"ve got a Takeuchi skid steer (10w-30), a large NH TS110 tractor (15w-40) and a NH backhoe LB75b (15w-40).
Standardizing engine oil on the farm would be a big benefit and buying a 55 gallon drum of engine oil would save some money. But what are the rules regarding OEM oil weights? Can I change the Takeuchi oil spec to match the NH equipment?
Yes I'm lazy and asking vs. internet searches but this forum has saved me from my stupidity many times so I thought to ask Experience first.
Vetech63
Oklahoma
You may get varying opinions on this. I personally use a good quality 15W40 engine oil for all my diesel engines. I've never had an issue with doing this but could be a problem in very cold climates. Since your in Tennesse, I wouldn't worry about it.
15W-40 is the most common oil recommended for diesel engines unless it's for colder temps. 10W-30 used to be specified in a lot of equipment like skid steers so that the same oil could be used for engine, hydraulics and chain cases. That recommendation has since been dropped. I think the reason could be that oils and additives have improved and specific oils give better performance and life expectancy. Also certain additives may not be compatible in the different applications.
Cogniz
Dayton,tn
Thanks Dave.
willie59
Knoxville TN
Service Manager
Is the Tak a gas engine? Diesel engines pretty much use 15W/40 across the board as it has additives for those engines. But 15W/40 can be used in gas engines as well. I use 15W/40 in my '85 300 six cylinder engine instead of modern 10W oils because 15W/40 has zinc in it, which is what my flat tappet old 300 needs. 10W and synthetic oils don't have that zinc content.
It would be interesting to see if there are any engine failures directly related to using 15W-40 instead of 10W-30 in a warm climate.
TCat
South, Alabama USA
Fleet Manager On My Island Of Misfit Toys
My late 1970’s John Deere farm tractor actually specs straight SAE 30 wt oil for the diesel engine for some reason. I was surprised to find that out after buying a bucket of 15w40 to do an oil change the first time.
In a cold climate if tolerances are that tight an 0W-40 might be more appropriate. There was a post not long ago about 0W-40 recommended in a JD engine.
chidog
wa
Many years ago we got an old Lexus LS-400 from a relative, he said all he used is 20W-50.
OK so those are the viscosities recommended by the OEMs.
But what API Service Classification are they asking for.? This is a totally separate issue to the recommended viscosity. Something below for reference.
TCat
South, Alabama USA
That brings back a bad memory of when I was a teenager with my first car, a 72 VW Beetle. I didn‘t understand oil viscosities and put 20w50 in it during an oil change, in the winter time. Yikes!!! I started it below 32 degrees the next morning and not only did it barely crank but it pegged my add on oil pressure gauge. Needless to say it was another street side cold evening oil change for me that night. Fortunately I didn’t blow the seals out of it. Lesson learned. Lol
712alberta
Alberta Canada
We run 5w40 in every diesel engine on our farm, and we run that year round. Never have had problems in the cold, feeding cattle or in the heat of the summer haying or spraying. It does really make it nice only having one oil, minimizes the changes of putting the wrong oil in an engine. Around here sometimes the sales they have, its cheaper to buy in pails vs barrels. We also use Hytran from CNH in all our hydraulic systems, regardless of brand of equipment. It meets all the specs from CNH, Versatile, and the AGCO products we have. It really streamlines everything when there is two oils for major components, and the a couple pails of various gear oil. If you ever end up with something that has a CVT or IVT they do require special oil from my understanding, and I also understand that there can be damage to various components if you don't use that type or grade of oil in the transmission.
willie59
Knoxville TN
Service Manager
Well, does a 1985 300 six cylinder count with I can't remember how many hundred thousand miles? When the odometer hits 99K it rolls back over to zero to start over again, I've lost count of the rollovers. 300K, 400K, can't remember. 4 qt 15W/40 Rotella and 1 qt Marvel Mystery oil at oil change and it's still going strong daily.
