We thought this might be the issue and took out the hydraulic pump and had it cleaned and reinstalled but the problem is still there.sounds like pump going out
Does the engine slow down when you try to drive up a hill in too high gear? and is there any smoke visible from the exhaust when it does? If no smoke, then I'd guess you're starving for fuel, like a plugged filter or something in the tank to the transfer pump.
