Coaldust
- Joined
- May 9, 2011
- Messages
- 3,611
- Location
- North of the 60
- Occupation
- Cargo Tanks, ULSD, RUG, Methanol, LPG
That was nice of you to write all that out, pumpguy.
Took the top cover fitting off. Cleaned it. It has what it looked like plastic check valve. Cranked the ignition, but no fuel came out from the top fitting of the pump. It came out from the water separator as I also removed the return fitting. Put everything back. Used manual pump, and started the engine. I try it again without the fitting and see. ThanksHas it started starting AFTER u took the fitting on the top cover out.??
If yes, it probably doesn’t have to many “revs nice” left in her..
Once it’s starts surging, shut it down and pull the pump..
What fitting were referring to? I thought you suggested removing the line on top cover of the pump and injectors lines then crank it. Maybe I misunderstood.I wouldn’t take it out.. that fitting is the only thing keeping u from buying an engine..
If it keeps clogging up and shutting the engine down, the pump needs to be looked at..
And like I said, once it starts surging, shut it down..
or it’ll shut itself down..& u won’t like how that happens..
Start saving your nickels and dimes now..
If both wires are disconnected and you measured zero resistance on both wires means the solenoid is shorted out and needs replacementI think I also have some electrical issues. I did a continuity test from negative of the battery to the two wires of the pump and both have continuity. Which means they are both grounded?
