If it does not, get a couple of teeth and weld those to the plate. Then you beat the pins out to remove it. That is the typical arrangement.
that has to feel so good to see gone gone!
Some of those scrap yard operators are really good. Others are really good at bending your trailer or truck.
Yes there is. It's called HIS (Hydraulic Information System) but is only available to Cat dealers and selected customers, to help them build hoses obviously. We had access to it because we had an on-site Cat hose shop. Chances of your getting the info - slim to none.@Nige The hose is supposedly a "263-7001 HOSE AS". Is there a way to tell how long it is and what fittings are involved?
Post some photos showing how the hoses are run.In other news, I think my stick hoses are routed incorrectly. They are outside the ears and I think they should be inside the ears.
The photos you found certainly look more “right” than your machine. Only the Parts Manual will reveal the full story.
The 4th pic in #214 shows the aux hose the other way up to your machine and the 3rd pic. Would think that would get quite a pull on it when the dipper is crowded all the way in towards the boom. How does yours look fully crowded, still big loop?
I would agree.This SIS2GO pic could be interpreted as indicating that the bucket hoses go through the ears:
Look for a part number tag on one or other of the steel lines that run along the boom on your machine then search your SIS for that number.The aux lines do not look like mine or the bulk of the photos I have found:
