Clearing scrub brush on hillsides? Looks like a large area! How's the 6D running?
Yea, trying to clean the noxious weed lantana which has taken over.
The dozer is running OK for it's age, it has not yet morphed into the D7R I want it to be, maybe it is like the frog and I have to kiss it
. Engine temperature is not an issue any more.
Transmission still has it's problem, been trying to get some pressure gauges to put on it. But I have narrowed down the problem.
It only intermittently part goes into gear when two things are met. First the oil has to be at normal operating temperature. Second there has to be a period of inactivity as in a couple of minutes in changing the state of the transmission.
So you could have warm oil, engine at idle, transmission sitting in neutral for a period of time, then sometimes it will not engage properly.
Or you could have had it on a long pull going up a hill engine flat out, then when you idle down to change direction, sometimes it will not correctly engage the gear. Or the same thing but a long run downhill at half revs.
Short runs of back and forward, it never does it.
So long periods of the transmission in the same state is the main factor. A sticking valve I am guessing that stops the transmission getting proper pressures to fully engage one of the clutches. Or maybe a suction side air leak letting air into the system.
Here is a photo looking back the other way from the picture I posted yesterday. I snapped it today. The over grown looking hill in the middle of the picture I plan to get a plane in and spray it with herbicide (agent orange)
to get rid of the crap, then burn it. It is just too rocky for my little dozer and stickrake. It would do it, but too rough on the gear.
And one for the rock doctors. Is this limestone? There is limestone in the district and marble. It does not look very much like marble to me.
