Maintenance season 580SK
AU.CASE
NSW Australia
Grazier // Rancher remote NSW
Due for some routine service, our 580SK had five cylinders in for leak solving with kits on hand.
We had a problem right at the end with the clam cylinders' and the genuine kit's piston seal was swollen over size and couldn't be kept in the lands for assembly also I didn't have a compressor which might have been required.
Had to revert to the old rings from the bin, still fair condition but disappointing that the genuine ones would not fit and were disfigured when I tried to load them.
All the aftermarket kits were cheap by comparison and fitted perfectly in other posts / later.
The rings appear to be metallised / sintered?
More steps before to follow in pictorial and I am on the home straight of a 1,038Hr full service to our 1150D elsewhere here, soon.
AU.CASE
NSW Australia
o rings in the freezer for hour get em to shrink & keep em cool. Nice fab up on glad wrench
Yo, thanks yes for the tip on rings, too late now and it was hot when I pushed through this, so that wouldn't have helped at all, maybe also they were six years old, could that matter?
The gland tool is for the 1¾" shafts and have another for the larger 2¼" which gets all the cylinders apart from the curl, which is easy with a generic fork tool.
I turned them from scrap in the workshop and they don't harm the piston shaft or bell out the face sockets in the gland, also can take a fair lever or tap or two to crack a stuck thread / seal.
AU.CASE
NSW Australia
Ha, you can see they have been delicately cheated on. lol
Yo, never afraid to put some more 'reach' on there, I not younger that I was ! ;)
Actually the handles are mild steel, oval boiler tubes and as you say only provide something for the cheat, most cylinders are pretty simple, some mild heat maybe and hammer over the thread if I must, most open with out a 'cheat' though.
Put plenty of grease on the outer seal / backup and the thread, makes life easier.
AU.CASE
NSW Australia
First of the set, was the extender, thought I work from difficult to simpler (theory anyway), next was the stabilisers :)eek: a mess in there packed with dirt to the top, poor old cylinder and gland, why the column is open at the foot surprised me) and last was the hoist clam).
The extender is interesting to solve, comes out fairly easily, hoses were sad so they were replaced, lots of leaked oil in there, one spacer shim was loose and required repair, shaft was bent (when aren't they), otherwise the cylinder was in good condition and out working today !.
Seal kits from Reliable were excellent.
This was 14MM peaked and straightened quite well.
Custom sockets for our CASE work, where 3/4" drive won't cut it and the top one is specially made for our "Adelaide Hydraulics" aftermarket "BD10 / Fiat Allis ripper. Shafts are 1 9/32' - 32.5MM HT plain bar.
Deere500a
Castro Valley ca
O rings age shouldn't matter good to use good to freeze. Nice project & learning wash the windows after stick the hose in the outriggers,open like that sounds like job security packing dirt around cylinder asking for broken fitting & wear
AU.CASE
NSW Australia
Yo, the rings were old stock (6yrs old actually piston rings G102288) and they fitted over without having to use the expander (kinked cut) which I haven't seen before. If I had a compressor, they might have worked? Just on the bench here, those rings are 76.31MM ID but the surfer lists them as 71.77MM?
No problems with seal and backup rings, plenty of grease, gets them done.
This, is the inside of the lift column, all over the cylinder, oh dear, historic dirt.
My my, hey hey > neglect, should have gone here years ago.
Next; All better ! :cool:
AU.CASE
NSW Australia
Oops, oil leak in the extender :rolleyes: rebuilding the stabiliser feet.
O-Ring outside the nipple, fit a new one and the loss of seven litres of oil in 44 hours goes away, bit of a task to get to the cylinder in the extender and there was a funny incident I didn't photo, but the boss said "yes I heard and saw that so, stayed indoors". :D
Pressing the distortion out of the feet broke the old jack in our press (it split the lower 1/3 of the cylinder) although 40 years old and this one works so easily compared to the small piston original. :cool:
Had to restore these feet before they became too weak to weld and I am surprised how abrasive life on bedrock is for these, we have some slate, quartz, flint and a blue sandstone.
Had to add 15MM on the inside and 12 MM outer wear build up, only have low hydrogen stick, must finish them today with a seal plate over the column port to keep the dirt back a little, if it works?
Deere500a
Castro Valley ca
Make the foot more ridged with the socket if would stress the tower? Swinging everything on that side.Dad had a JD 315a & Ford,** others bottom outriggers had pin pull make a wider foot print why he bought A over a B all hoes up date all switch to same vertical stabilizers cheaper?? Rare to find a Deere or Cat in the states with offset JCB doesn't offer a model here
AU.CASE
NSW Australia
Shouldn't as the 'footprint' is still the same area and size as original, however I have noticed that the feet have cut into the corners of the slider which supports the machine in each rear corner tower, so they will have to come out and have some restorative welding to stem the cracks that are forming.
Yo, would be right, this machine is EU make and nearly all here are side shift.
There is merit to both, with side shift I can stand next to a structure and work, but it probably won't be as stable or monitor how the machine is sinking compared to the centre mount 'hoe.
Deere500a
Castro Valley ca
Offset was common 50yrs ago it was a extra same as digmor & 4/1 for hourly hire. Hoes had manual pin to pull slide out outrigger if needed a wider baseScreenshot_20260509-200007~3.png
AU.CASE
NSW Australia
For an initially unknown reason the parking brake alert buzzer went silent late last week.
Wrongly assuming that the contact switch in the cabin handle would be the culprit, I removed the glove box, D.C. isolator switch (my mod), fibreglass firewall console, but not the steering wheel.
Quick check with the multimeter confirmed that both terminals had continuity to frame when closed and, it was then that I recalled a 3 cable line underneath in the clutch and brake interlock that had lost its lock barbs.
Sure enough, it seperated completely once I touched it on the RHS loom along the Hydraulic tank / front of the transaxle.
Anyway it turned into a bit of a saga, the mat came up and so did the front floor panel and I noticed the D141049 parking brake boot was an old problem that had the new part in stock here to seal it.
So that is on for tomorrow, had a migraine start when under the machine, so gave up for the day.
This is the park brake switch, open circuit when the brake is fully off.
This is the 3x connector which has lost its lock catch, now cleaned, some vaseline on the pins and small cable tie between the cables over each end.
AU.CASE
NSW Australia
Never heard of using Vaseline? Hopefully it’s non conductive?
Yes it will only keep oxygen out of the way and I have used it on communications' cables for years on towers' as it keeps the connection free of oxidation, or like new and it has long term composition stability.
Vaseline - "Snow White Petrolatum,", oil workers' found it accumulating on plumbing and that it helped heal sores!
AU.CASE
NSW Australia
Working through a slew of routine tasks and accrued problems, a couple I'd need help with here. :cool:
Quite a bit of dismantling to reach the D141049 park brake actuator, simple enough once reaching in from the top through the floor panel.
I'm transferring to Donaldson filtration, now we have a local dealer, very high quality products, so am working my CASE stock filters through without fluid change, rather than tip them.
Jobs, change D141049 boot, repair wiring loom connector in the park brake and clutch interlock, break and clean as many loom connectors (and make) after some Vaseline on the pins (one had minor assembly dirt in it), Hydraulic filter - bit messy but done, pump grease through primary and secondary propeller shafts uni joints, repair rodent damage on air intake rubber sealer, Oil filter swap out, Fuel filter swap out, repair cracks in steering tower moulded shells, clean cab floor, treat rust, clean transmission, clean engine area, radiator air clean, alternator air clean.
Next to fix / solve, Transmission filter (not in stock :confused:) buying in Donaldson, RHS epicyclic transmission on Carraro front axle has intermittent (1349265C1) main seal leak through annular groove to outer hub, King Pin kit due, Carraro driveshaft ?axle uni tractor joints, blade cutting edge detachment.
Is this over cautious?
Had a look at this last thing tonight and its worse than I first thought, the work has separated the skin behind the cutting edge, rock and soil are pressing in and levering the edge away from the blade body only on the LHS.
I wasn't going to fix this but, it is time and I have a grader cutting edge I thought to get it cut down to 3" and replace this old cutting edge, even though its a bit thicker bar.
My question is, how will trying to weld cutting edge steel to this with a stick welder work or, fail?
How long can I expect these tractor joints / double uni's in the Carraro front axle assembly to last?
Those uni's / spiders look very dry, thirty years old.
Should I (when servicing the epicyclic / planetary transmission) dismantle the uni / spider joints and repack them with grease, or better still replace with new 84355357 uni's, what do others fix these with?
I reckon they are dry and could do a lot of damage if they crack up (which they won't though).
I notice some replacements have a grease nipple (zerk) but it must be impossible to reach in there?
