Miguel0077
I’ve got an ECR88 and need to pull the swing motor. What’s the correct procedure? Where do you start the removal — from the top under the cab, or from underneath? Which parts do I need to remove to access it properly (cab lift, panels, slew ring cover, etc.)?
Any tips to avoid headaches? Things like trapped pressure, hoses that are tight to reach, or bolts that usually seize?
Thanks in advance
Thanks in advance
