Linde H45T 394 Series (VW LPG) Overheating, Cooling System Problem
Hi, I have a Linde H45T which overheats and shuts-down after 10-15 minutes. At which time coolant overflow it evident. I presume this is due to the coolant overheating? ... I should point out that I'm somewhat mechanically challenged.Subsequent steep learning curb, I serviced the engine oil and filter, air filter, hydraulic oil filters (X2) and replaced the water pump. Even though the internal rotor blades of the pump were broken, the new replacement did not seem to resolve anything.
I also flushed the radiator which had the incorrect (green) coolant and renewed with the correct red coolant and demineralised water. Even though I flushed the system several times before refilling with red coolant, it expelled pure green coolant upon first trial run, post the water pump and coolant change-over. I'm only mentioning this in case it may indicate a blockage issue?
The radiator fan seems to operate OK, but I believe that there is a secondary auxiliary water pump and fan which operates when unit is turned off etc? I don't believe that this fan is operating. I have no idea where this fan is located, but I presume that I should be able to hear it. Should I now focus on the thermostat?
Lastly, could a poor battery cause related issues? If so, I should divulge that I'm relying on jumpstarting, thinking that the battery will come good once I am able to run the unit for more than 10 minutes at a time.
Any advice would be much appreciated.
