Innocent bystander
I have a Volvo L90H Loader that has low power below 1500 RPM. if at idle and you give it throttle in gear it will go up to about 1000 RPM and either goes no higher or very slowly up to 1500 then take off normally from there. Especially if you are already moving then slow down, as the RPMs drop down to around 1000 as you lay back into the throttle the RPMs will just hang out around 1000 and wont go no higher. I have PTT and Prosis and have been through everything that I could find including passing all tests in PTT.
-No fault codes
-TPS in Data always shows actual(Shows 100% when stuck at 1000)
-Engine is not bogging down or missing
-It will always rev up if in neutral. In gear under load is when it acts up
-Fuel supply is in spec and never drops off
-Rail pressure always equals commanded
-I have a sister machine that I have compared all data and cant find anything out of range except fuel injection mass.
If I floor the throttle in gear on sister machine injection mass goes almost instantly to 65.
If I do the same with problem machine it goes up to 35 and hangs there for a bit and slowly builds up to 65-70 as it builds power. I assume injection mass is calculated but not sure or how it calculates it.
-No fault codes
