L9000 door hinges
I'm trying to loosen up stiff door hinges on a Ford L9000. I took the grease fittings out and of course they're plugged. I sprayed some penetrating oil and heated them which helped some. Hoping someone can confirm the grease fittings are 1/4"-28 thread? They're pretty small. Also should I try to get grease in them or use some other kind of lubricant?
cuttin edge
NB Canada
Finish grader operator
Bowman used to have amazing products for that stuff. Chrysler has a good rust blaster no idea who makes it
Does appear to be 1/4"-24 thread grease fittings. Was surprised NAPA didn't have them.
They are a short thread 1/4"-24 fitting. I found a pack of 5 at a farm type store. Canadian Tire had a pack of 10 as well but I only need 4 at the most. Really surprised two NAPA's didn't have them.
