L60H cant regen due to SCR status
heymccall
Western Pennsylvania
Currently @ 140% soot load.
Can't regen with cab switch or IDC6 or jaltest, because the SCR tests get stuck at "dosing valve check".
DEF injector was crystallized completely, and cleaned by soaking in hot water
Initially, I could get to manual regen screen on my IDC6, but get stuck at "dosing valve check". After cleaning injector, IDC6 says 20260611_140129.jpg
Now, on jaltest, I'm simply stuck at "dosing valve check".
Only codes
Is "dosing valve check" looking for a slight pressure drop when test cycling the DEF injector? Why is it plural? Are there multiple "valves"?
Is like a Caterpillar where it equivalent to a level 3, requiring a factory password?
Bullitt
Central PA
Manitou / Gehl & Yanmar Tech, Rental Monkey
Is that coolant and pressure diff sensor code active? Not familiar with that software, but if those are active they could very well be blocking the regen logic. I've had countless issues with Jaltest and Volvo CE that just worked using PTT. The Jaltest interface actually does work with PTT if you look into going down that road.
heymccall
Cleared codes upon arrival.
Everything stayed gone save for the dpf codes. The others were inactive just as you see, before code clearing.
So now, just the dpf codes.
pumkinhead
michigan
can you reset the soot level and run a forced regen? did you do a def dosing test after cleaning the injector? on a separate note how do you like the IDC6 and jaltest, which do you prefer and why and hows it compare to oem software. im looking a potentially getting one or the other
heymccall
Back again.
Able to force regen, but...
Temps never get over 270°C, even after 10 minutes.
I don't see a hydrocarbon injector anywhere on this thing.
Any guidance would be greatly appreciated.
heymccall
I've come to verify that, yes, regen is fuel controlled via post combustion injection at the 6 fuel injectors.
I just don't know what else to inspect/ clean/ replace to allow regen temps to climb.
Clean, fresh fuel/ air filters are in there.
Runs well. Just goes into derate with high soot load, and forced regens never get hot enough.
pumkinhead
michigan
are there any active codes? can you download a regen report? have you cheeked the inlet throttle restricting valve?
Mr. Wrench
Ohio
Mechanic
This is just kind of a guess, but it seems like some machines I have worked on when the soot/ash level gets to high they do not have enough flow to be able to get hot enough to regen. Seems like they have to be taken apart and cleaned/baked at that point. Maybe someone else can confirm if that is right.
Mr. Wrench
Ohio
Mechanic
Depending on the machine the DPF is not very hard to get out sometimes. Have it cleaned and you are starting with a fresh one. Just be sure to reset the DPF counter and/or ash load whatever your diagnostic tool has.
pumkinhead
michigan
I doubt your dpf Is plugged, did you run a def injector dosing test after you cleaned it? And was the mixing pipe also crystallized, what where the initial codes before cleaning
EGT sensors DOC/DPF have been known to show cold although it's at temp forcing
ecm to stop regen. Same with NOX and pressure sensors. But have had issues with
plugged DEF causing low flow even though pressure sensor showed low, but that's
on a Daimler product too. May have zero to do with your issue.
Ben Witter
On the outside
There is a self check of the DEF dosing system at the startup of a parked or service regeneration as the DEF dosing is used to cool the SCR assembly. If this self check does not pass it will not continue through the process. As asked have you performed a DEF dosing test? You will need to diagnose and correct the issue with the DEF dosing system before you can proceed.
Also as stated most active engine or ACM faults will inhibit a regeneration. DPF differential pressures do not generally start to cause issues until above 5-7kpa
