Innocent bystander
L150H 007181 Fan keeps slowing down to 150-190 RPM then machine runs hot.
All brake/accumulator tests pass(unless Im missing something).
Pump 3 runs brakes first then after accumulators charge to cut-off pressure then pressure goes to fan.
At start up brake pressure cut-out pressure is spot on spec at 2250 psi then fan kicks up, once machine gets to operating temp and starts working, brake pressure will go to 2500-2600 Psi and will not cut-out thus never spins up the fan.
Any ideas?
Thanks.
Any ideas?
Thanks.
