Komatsu 300lc-7 multi-function slow
Mzdiesel
SC
Hey all, I’m looking at a komatsu 300 LC -7, I believe. Serial #A90215. I believe I am dealing with a lot of leakage/ priority issue. The main complaint is that you cannot perform two functions at the same time. If you raise boom and bucket the boom will pretty much stop same for bucket and stick. It’s almost like when resolvers go out in a back hoe or a motor grader. I am not too experienced with komatsu or these pilot operated systems even though that’s what a majority of them are. I got into this trade about two years ago and have a lot to learn. I know my way around electro- hydraulic systems but those are simpler. I know they are similar and I’m assuming this system is using two way two pump flow for most actions I need to verify what pumps, reliefs, bypass, valves are associated each function that way I can find a common denominator. Can someone provide me with a schematic or systems op so I can think my way through this? It’s kind of hard to figure out where to start. I don’t have any bypassing cylinders, oil is good, I believe pilot pressure is good, I believe main pump pressure is good but it seems like there is a signal leakage or something is not telling the pumps to either upstroke or sending flow the wrong way. I also observed a very weird action; when you would stall bucket curl in after you let go the swing would turn to the right a little! Lol this thing is a work of art but I want to learn more about it and i feel like if I can get a schematic and some help I can find the common denominator. I believe there is also an active code for bucket curl sensor but I’m not sure if that would cause all these issues. Any help is appreciated, thanks View attachment IMG_1909.jpeg
John C.
I would check the engine for fuel and air supply issues first. The system is load sensing on the engine and if the engine isn't putting out enough horse power you will get the symptoms you are speaking of. You will also need to clear out those fault codes. You have a lot of hours showing on the monitor panel so you may also have other issues. I'll check what I have in my library for a service manual.
John C.
I have PC400-7 and PC200-7 service manuals in PDF. The systems will work the same but there will be some differences in the places of the components. If someone doesn't give you a lead on a 300 model book let me know.
Mzdiesel
SC
You make a good point, I did order some fuel and air filters
Mzdiesel
SC
Yeah I’ll take you up on that offer for the 200 manual whenever you get a chance. I’ll give it a look and it will at least give me some frame work.
Capiz Philippines
Hey john, any chance i can get a copy of that pc200-7 manual(sebm024314)? I'm willing to pay but here in my country we only have g cash. i don't know how i would be able to transfer money international. I've been really desperate for that manual
