kobelco sk045 yutani excavator
upali yapa
sri lanka
mechanic
Dear friends,
i have a kobelco yutani sk045 excavator. serial number LP-01603.Its hydraulic pump model KAWASAKI NV64DT. I Disassembled the pump and replace pistons, swash plate, retainer plate etc, and i rebuild as new one.
Now machine has many problems.
1) engine heat go to red line.
2) black smoke .
I was trying to fix it adjusting pressure and tuning screws on the pump.
now every thing messed up.
if you have a manual or any detail about adjusting pressure and pump
pleas help me.
thank you.
mikebramel
milwaukee
You need gauges
Sounds like the Idle/Standby/Pressure differential is set too high. and Possibly the Cut off is set higher than the main relief pressure
upali yapa
sri lanka
mechanic
thank you mikebramel
Yes I have pressure gauges, (400bar and 100 bar)
I have a parts manual,I like to send it to you,
Because you can use ti to explain me something like gauges connecting ports and adjusting places.
mikebramel
milwaukee
If you look in your last picture, two spots to the LEFT of the "A" is a port plug. There are probably several on the machine. I would try taking pressure readings form these ports
upali yapa
sri lanka
mechanic
How to adjust B,and C.
gauge port A,
mikebramel
milwaukee
You're going to have to find the line/main/outlet pressure port and the signal/load sensing/pressure differential port on the pump. The main relief valve will be closest to the inlet of the valve. Turn that OUT until you have say 3000psi stalled. If pressure is lower, adjust compensator on pump (which will typically be the large adjustment) IN for more pressure. But when pressure stops increasing, turn back out atleast 1/4" turn otherwise you WILL overheat.
At idle, the gauge reading to the signal/load sensing/pressure differential port on the pump should read close to 0psi with no functions/in neutral. BUT the the line/main/outlet pressure should read around 3-400PSI. The signal/load sensing/pressure differential port will be connected to one of the smaller lines running to the pump controller.
upali yapa
sri lanka
mechanic
Dear Mikebramel,
please can you tell me the procedure to adjust main relief valve and over load relief valve.
other thing is
what is the relief pressure of ......?
1) Boom, Arm, Bucket
2) swing
3) Travel
I have 2 pressure gauges, (400 kgf/m²)
I will connect the gauges to the port X and Y.
After that tell me how to adjust pump.
thank you.
