Kenworth
Do you know anything about why they built it?
No idea, it resides somewhere in Utah. But companies like American Line Builders that were
around here at one time, built a lot of their own off road transmission line trucks. There was
a KW roughly that vintage here some years back that a constructed 6x6. Along with several
other oddities just like the one below, it was built by ALB.
In two's--Tow truck fan clutch started leaking air, fan hub is 4 years old hoses 6 years old.
Couldn't hear a leak--soapy watered everything--feed line from air solenoid formed a huge
bubble in a 6" area. I don't think that hose had 35,000 miles on it, but it ruptured inside out.
So this time I had a hydraulic hose made to fit--the old one was good to 500 psi.
There was a KW tug at Boeing Field Seattle back in the mid 70's, might have been several,
but I only saw the one.
Wonder who made the ground power unit? Grill looks like a Hobart. Hobart made the first ground power unit in the US in 1946. I didn't realize they still make them as part of ITW.
Back in those years diesel power was not considered reliable by certain standards, mostly
cold weather starting and batteries/starters were the issues.
The possibility of a T shape sump pan, or just one long sump front to back makes for
shallower pan, but they didn't care as long as it had 5" clearance. Always on tarmac or
runway.
Yes and thank goodness died away in mid 80's.
I don't remember it because I never dealt with firetrucks/buses or concrete pumpers.
Items I've never bothered to give a minutes thought, just tools with wheels that have
zero exterior personality. Other than the music from sirens or a ad spinning around on
a concrete mixer truck drum. The only items that I will agree with my brother on {seen one
cement mixer you've seen them all}. I worked on detroit two strokes, personally never
cared for the nasty leaking or noisy messes, those did the job and faded into history
thankfully.
