John Deere 644G Parking Brake Comes On when The Transmission oil warms up after use for about 30mins to 60mins
Mikepd177
USA
Hi, hopefully, someone else had a similar experience and can give me some guidance. I have a 1993 644G loader with about 9300hrs, The Unit works fine under light load for a longer period. Once the unit starts working and the transmission oil indicator gets to about 1/2 or a little above the warm markings the park brake light comes on and locks the machine. Once the transmission oil cools, I can use it again until the oil warms up. I'll list what I've tried below.
- Change Transmission oil and filter
- Change the Oil Cooler Filter
- Clean the oil cooler with low-pressure water
- removed the thermostat from the bypass valve
Try rebuilding the park brake pump. Had a similar problem. Chased down all the pressures and solenoids for a half a year till I took apart that pump.
