John Deere 450J Hydrostatic/TCU/Drive Issues
ian8or
Tennessee
First off, let me start by saying, I am by no means a heavy equipment mechanic. But I am fairly mechanically inclined and typically am capable of figuring things out/fixing them myself if I mess with it enough :p This will be lengthy but i’m trying to give everything i know and have done thus far. Any help is greatly appreciated. So, let’s get into it.
John Deere 450J: SN: 1TO450JXKCD218918
1 Active Code: TCU 523108.14
17 Stored Codes: 908.12, 907.12, 97.3, 1638.3, 523577.9, 523578.9, 522444.4, 2661.4, 2660.4, 522448.5, 522450.6, 522449.5, 96.3, 157.17, 91.9, 522447.6, 522447.5 (I know holy sh*t)
This dozer is a buddies. It has pulled left and had speed sensor codes for a while to my knowledge. I am not entirely sure the exact length of time but it has been ran that way for quite some time. A friend of ours (JD mechanic at the time worked on the dozer several years back and i believe did a null adjustment on it and got it tracking pretty good and straight but it still had a slight left hand pull. Probably had 2-300 hours put on it then it sat for almost a year and was not ran. I bought a piece of property and have borrowed the dozer and used it for several hours as well with it pulling left just mainly cleaning up brush and small trees. No heavy pushing or abuse. The dozer sat for 3-4 months throughout the winter and was essentially untouched. Come spring this year i began working on the property again. Dozer fired right up and i put it to work. I probably had 2 hours on it when the current issue occurred. As i was tracking back for another push of dirt the dozer locked the right hand track and on its own threw full power to the Left track. Took off spinning right. No matter the position of the drive joystick it sends juice to the left track only. It should also be noted that upon start up if you do not throw the park brake lever down that the dozer will stall out because the pump is loading up trying to send fluid to the left track.
I called that same friend (unfortunately he no longer works at deere, but he does now run his own service truck and has access to John Deere service advisor with all the manuals) he inspected the machine and narrowed it down to the PCP. You could unplug PCP and machine would idle just fine. As soon as you plugged in PCP machine would die unless you immediately threw the park lever down so that the left track was free to spin. 1550 dollars later machine has a new PCP… No dice. Didn’t fix it. Didn’t change a thing matter of fact. I can tell my friend that’s worked on it a few times really is not interested in messing with this thing. Nor does he have quite the access to parts that he used to at deere where he could swap say a new TCU on to see if that fixed issue or not. I myself located the speed sensors at back of machine and managed to get enough slack in harness that i could plug left to right and right to left. Same issue. Left track still wanting to spin on its own with right track locked tight. That leads me to believe that something internally on the pump must be stuck. Prefer not to have to call a John Deere service tech out but it’s looking like that may be what has to happen. Any tips and advice is much appreciated. I’ll also add this machine is an open cab and has spent likely its entire life but definitely last 6-7 years outside in the elements. The TCU doesn’t look the greatest but the connectors are clean and corrosion free.
ian8or
Tennessee
The only active code for the short little bit i can get the machine to run while it’s acting up is that TCU code: 523108.14
I am not sure how to clear the codes.
ian8or
Tennessee
Also i do not know the proper term for it but the small “switch” that is on the PCP i can manipulate and you can really hear and feel the machine/pump whine. It will spin in a circle for about 8-10 seconds and then die out. That side drive motor engages immediately so it’s not even enough time for the machine to be able to get the idle up before it just bogs and stalls out.
ian8or
Tennessee
Figured out how to clear codes. Cleared them. No stored codes left, just the one active that i listed above.
mg2361
Pennsylvania
Equipment Mechanic
That is a pump speed sensor calibration incomplete code. That will not cause the machine to turn in circles on its own.
You mentioned that with the PCP disconnected, the machine will sit still and idle fine, correct? You also mentioned that the wires from the front pump and rear pump were switched and the issue remained with the same track, correct?
Has anyone checked the PCP differential pressure? The PDCV differential pressure?
ian8or
Tennessee
Correct. The PCP that is directly in your line of sight when you pull the floor pan off is the one that was replaced. I would call this the “Rear” pcp. If you unplug it the machine will sit and idle. You plug it in, pump loads up and stalls the machine.
I swapped the wires between left and right wheel speed sensors at the back of the machine. This did not make the problem swap sides. Issue stayed the same.
No, the PCP differential pressure has not been checked or PCDV. I was told by my friend a special set of gauges was needed to do this with a special transducer. Is that accurate?
mg2361
Pennsylvania
Equipment Mechanic
Swap the PCP connectors from the front pump to the rear pump. Does the issue move to the right side?
You should use a differential pressure gauge for accuracy, but it can be done with two gauges if you confirmed they read the same.
ian8or
Tennessee
I am not near dozer currently, but from what i remember the two wire Deutsch connector that’s in the harness doesn’t seem like it would have enough slack to reach the opposing PCP. I will attempt to swap them though and report back. What is the testing procedure for the differential pressure? What values would i be looking for ? I see in other forums where you’ve commented that a set of hoses connected to a Tee with shut off valves on each side can be used. Would that apply here as well?
Steve Austin
Tullahoma TN
You stated in your post that if you unplug the PCP the machine will idle and not stall out.
Is this statement correct?
If this is the case i would thank you would not have a mechanical problem in the pump or the pump displacement control valve.
I would suspect a wiring issue or TCU issue. I have seen cases where a bad harness has juiced up the PCP with battery voltage which creates a very dangerous situation unless the operator is savvy enough to turn off ignition switch.
Steve Austin
Tullahoma TN
SAFETY ALERT if you are working on one of these dozers in this condition and has a lot of hours the park brake disks may be worn enough that the machine can drive right through the park, been there experienced that lucky to still be here. Keep all by standers at a safe distance.
One thing you can try if you have a clear area let the dozer continue to go in circles to see if the TCU can shut the hydro down, it should if it is working properly.
ian8or
Tennessee
That is correct.
I have not had time to mess with the machine here the past couple of days. I have ran two brand new wires and new deutsch connector with new pins direct from the TCU on the fender right out of the harness straight down the to the new pcp. Still the same issue. That at least in my mind eliminates a wiring issue. So bad TCU? What kind of voltages would i be looking to see on the blue T38 and T41 while the machine should be in a neutral position? What voltage should i see in Forward?
Steve Austin
Tullahoma TN
I not sure but that may be a milliamp signal to the pcp.
Unplug both pcp and do a comparison test.
Have you ever tried to perform a TCU calibration procedure?
The TCU can do some weird crap if calibration was not completed.
Does the window in the TCU appear cloudy or have moisture behind it.
Could you send us a photo of the TCU.
How many hours on the dozer.
masterwelder
NY
Just one more thing as far as safety- most typical brass ball valves do not have a maximum working pressure range to be used in any hydraulic circuit.
I have seen them used and fail.
McMaster Carr is just one of many vendors for affordable steel ball valves suitable for hydraulic applications.
Steve Austin
Tullahoma TN
This doesn’t pertain to this machine but this is funny.
One of my old coworkers from years ago called had a 240DLC that had set all winter and had no hydraulics.
Said he manually checked pilot pressure and was good.
Had him go into monitor check pilot pressure for a couple functions had none.
Told him probably some furry critters had spent the winter in the panel under the cab an chewd the wires in too going to pilot shut off solenoid.
This will be the third time I have seen this.
