455c-driver
2022 deere 35g:
I need to replace the rod end hose for the blade lift cylinder. Accessing the end of the hose that connects to the cylinder is straightforward, but getting to the other end is not so simple. The other end goes into a hole under the cab. By looking at the parts diagram, the other end of the hose appears to connect at the center post.
Can the hidden (by hidden I mean that the when you're down at the blade and and following the hose from the blade cylinder, it disappears into a hole under the center of the cab) end of the hose be accessed by tilting the cab? Or is there another way (other than hoisting the whole cab assembly)? Stumped for now. Any suggestions are very much appreciated!
