John deer 225c lc auto idle not working
Diesel Dave
Ontario Canada
All the pilot pressure sensors (9,A,b,c ) have readings when operating the various functions ?
You say the Front Att Operation sensor (d) circuit is not working which is likely why the auto idle isn’t functioning properly. Doesn't explain why the idle speed is high with auto idle off tho.
The Front Att operation sensor is located on the side of the swing motor housing, check the wiring harness and the terminals on the sensor.
Raptor exc
Vermont usa
The front att opération sensor d circuit is workin I get a 1 when operating I cleaned the conector
Engine on lever down operating
L1-e
L2-e
0-0
1-0
2-every function
3-every function except curling the bucket
4- every function except swing
5-every function except bucket
6-750 but real rpm is 1375
7-2.5 when dial is at 0
8-0.5 to4.4
9-only boom up
À-only stick in
B-only swing
C-forward and reverse
D-every function except travel
E-nothing 0.0
F-nothing 0
Whit auto idle on, dial to max i get 2000rpm for 3 second then drop to 1700 if i move joystick goes back up to 2000,but never go down to 750 rpm
Steve Austin
Tullahoma TN
Not trying to get anyone off track here but looking in parts the 225 has an engine learning switch. I know service manual says not used on some models but I do know if it gets bumped out of neural position will cause engine speed problems even when manual states not used. Simple check worth a look.
Steve Austin
Tullahoma TN
Not sure on the 225 but on other models around the fuse panel it is a small switch not much travel between positions I have seen these get bumped out of position especially if you have items stored in the cab.
Diesel Dave
Ontario Canada
The 225C has an engine speed learning switch that @Steve Austin mentioned.
When you find the switch and you find it in the middle (normal) position then an engine speed adjustment and engine learning may be the next step.
Raptor exc
Vermont usa
I found the switch it is in the middle it has never been moved. For now my excavator is working,is there a risk that engine learning would prevent me of finishing this job?
Thank!!
