JD 5100E communication Problem
meheis33
Alvin TX
Master Mechanic
Hello everyone, this is my first post:
I Work for a school district that has a JD 5100E tractor the unit serial # is 1LV5100ELHH402709 it is a 2017 with 2000 hours.
the unit has 4 codes: 3216.09 - Inlet NOx sensor loss of communication, 3226.09 - Outlet NOx sensor loss of communication, 3516.09 - Tank Heater fault - loss of communication and a code 5128.06 ? - have no idea.
(I will be ordering the service manual to acquire the wiring schematics and diagrams as soon as I receive a PO for the purchase.)
I haven't dug into the unit as of yet, but just wanted to reach out to see if this problems is common or do I have start going wire by wire chasing this thing down.
mg2361
Pennsylvania
Equipment Mechanic
Welcome to HEF meheis33;)!
There is not much Deere AG info here on HEF. Since that machine has a 4045 engine, and I don't know what level engine controller it has, I randomly chose a FT4 manual and I will PM you information on the 3216 code.
Hopefully you ordered the engine manual for that machine. Those codes will not likely be in the machine manual. But I can't say for sure since I do not deal with AG.
meheis33
Alvin TX
Master Mechanic
MG2361, Thank you for all your help. I was able to order the Manual (engine performance - 500.00 bucks + engine repair 500.00).
But also found out that the tractor only has 2 more weeks left of emission warranty (it will also take two weeks before the manual arrives).
We flipped a coin and decided to take the tractor to John Deere and hope that good luck will be on our side and the repair falls under warranty.
mg2361
Pennsylvania
Equipment Mechanic
Yep, you are right. I didn't look. You have 20 days remaining for the emissions warranty.
Let us know the end result.
Lwebb
Fairfield, Illinois
New to the forum here, currently dealing with a 5100m. Has intermittent 3216.09 and 3226.09.
Found this thread and was wondering what the outcome was.
Thanks
