JCB JS130 power dropping under load
5111
Estonia
The JCB JS130 with serial number 2134576 is experiencing power loss under load conditions.
The issue is not constant but it can show up when the operator is working the machine under higher load.
I suspect it could be related to the fuel supply. Operator has been replaced the fuel supply pump and filters, but the problem remains. The operator also noticed that P0087 (Fuel Rail Pressure Too Low) appears when the issue occurs.
Is it possible that there is an inline filter somewhere in the fuel system that could be partially blocked?
