Isuzu 6bd1 hard start
Isuzu6bd1
Eire
Have a isuzu 6bd1 in a hitachi ex200.. Hard to start, will start easy on sniff and run all day no problem.. Just starting hot or cold is a problem, not using oil or down on power, fuel lines and banjo filters all are good.. Starter motor may be a lil slow but not bad.. Any idea what to try
Isuzu6bd1
Eire
Welcome to HEF @Isuzu6bd1
There is a flexible coupling that drives the injector pump, it may be begining to fail.
Wouldn't hurt to check compression as well.
Sorry forgot to say compression is good also checked.. Will check the coupling on the pump it does seem like a diesel problem.. thank you
Cliffy
Worn injectors with excessive leakoff can cause hard start issues as well. Leakoff volume is to high to reach popoff pressure at low rpms. What was the compression psi? By the spec sheet above should be 441psi.
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
Doesn’t that mdl pump have a supply pump bolted to the side.?
Try hand pumping it before turning the key.. that’ll tell u if there’s a supply problem..
Good luck..
1 more thing.. I think that mdl has a plastic filter screen in the banjo bolt below the hand primer..(fuel inlet)
Tones
Ubique
Good luck..
They sure do. Also in those pumps there's plastic plungers that get pitted over time and won't pump fuel. They're easy to replace and cheap as chips.
Isuzu6bd1
Eire
Ah ok.. I haven't performed the compression test myself was by someone else who said it was in spec..
Isuzu6bd1
Eire
Good luck..
Yes have tried pumping it up before start made no difference.. Yes all screens and filters have been changed alrite still the same issue thanks
Isuzu6bd1
Eire
Seems to be pumping lots no problem filling the lines and filter after change one thing I'm wondering about is pump timing maybe
thepumpguysc
It might be the pumping plungers inthe pump itself.??
Not pumping enough fuel to start the engine..but run fine afterwards..
Do u have any fuel in the oil.??
THATS a clue that the p&b’s are worn..
Isuzu6bd1
Eire
Ah rite ok.. No fuel in the oil or at least not obvious.. Going to get back to it in afew days and try afew more things
thepumpguysc
Another thing u can do is:
Remove an injector and hook it back up to the line..OUTSIDE THE ENGINE..& crank the engine..& see if it’s popping open the injector..
DO NOT GET NEAR THE SPRAY..
The spray WILL penetrate your skin and you’ll get blood poisoning..
Good luck
Isuzu6bd1
Eire
Problem sorted..rack on pump seemed to be stuck..screwed off cap and moved manually and starting perfect again..what is the idea of adjustment screw in the end or how should that be adjusted or removed fully
thepumpguysc
That’s to limit the starting fuel..
So it doesn’t wash down the cylinders with to much fuel..
The adjuster is usually a 4 or 5mm Allen screw..??
If so, u can turn it “IN” a full turn or 2..
To be on the safe side, adjust the screw and put the cap on and give it a test start..
Good luck
Isuzu6bd1
Eire
Good luck
Ah ok.. no just an 11mm bolt with a lock nut.. is there any way to adjust it to spec or just trial and error..barely cranking and it's starting now which is great
thepumpguysc
The cranking/starting fuel is set with the pump on a test stand using test injectors..
What u can do is: seeing it’s starting NOW.. back the screw OUT a turn at a time until it fails to start..
THEN turn it IN a turn at a time until it starts..and lock it down there..
Be sure to put the cap back on after each turn and test..
Isuzu6bd1
Eire
Perfect wil give that a try thanks
