Started 1st of July, was dumping a load and died on me. Had mechanic come out 1st mechanic said icp pressure so changed icp, didn't help next time came out said thought might be ipr so picked up aftermarket ipr, mechanic came out his "pro something" diagnostic tool not linking up, put ipr in hoping was problematic, didn't help.At this point it was running sounded good till warmed up then 333 code comes up. Called international mechanic, came out put guage on hpop was getting g 4000 psi so he said was injectors, had new injectors put in. Pulled 333 code and into limpmode, put in navistar ipc and ipr would still running sounding good till warmed up then pulls code a d misses and eventually dies. Internationalechanic again hooked guage to hpop and got reedi g of 500 psi on both diagnostic tool and guage. Took guage off and then wouldn't start. Replaced remanufacutured hpop and still no start. Mechanic going g to check hpop tomorrow and try to get started if I can't today. Only runs 2 batteries with 950 cranking psi each 1st one on charged was 85% haven't put 2nd one on charger yet, would both batteries at 85% cause no start?
