Columbo
So, in a previous thread I asked for advice for a medium duty farm truck for my brother’s farm. He found a purchased and International 4700 with the T444E. Truck seems to be well maintained, started easily and ran great for the 3 hr drive home.
I looked it over a day or two after he brought it to the farm, it was hesitant to start then and required multiple cranks to start (at the time we attributed it to cold weather). After it started, it ran smoothly and I drove it a bit. Nothing unusual driving, good power and ran smooth. After I parked it, the truck sat for a week or so before my brother tried starting it again. Now, it will not start.
Truck cranks freely, battery and starter seem fine. Just a little light grayish smoke from the exhaust when cranking. He changed the fuel filter, cleaned the pre-strainer and put a gauge on the low pressure test port after the fuel filter. 40 psi on this port, which the manual indicates is normal. Thoughts on what to test next? I’m thinking the injector pump has air in it or the shut off solenoid is faulty. Thanks to @mekanik we have a service manual for this engine and will be working through the troubleshooting process.
