I have a Doosan P185 that cranks but can't start
Brianr3989
colorado
I have P185 with a JD motor it cranks and tries to start but can't. I have checked fuel shut off and replace fuel pump. I checked all fuses and all good. Can anyone help me find out what else to check?
MarshallPowerGen
NW USA
Generator Technician & Equipment Mechanic
New issue while running, or has it been sitting a while and now not starting? 4024 pumps and injectors stick/crap out with bad fuel sitting in them.
Brianr3989
colorado
It was running then stop and they tried to restart it till the battery's died. Then parked it in the yard. so i couldn't get any codes or anything
Brianr3989
colorado
I have check fuel replace fuel filters and the housing. check all fuses. Also I but in a inline fuel pump to see and still the same.
funwithfuel
Will county Illinois
Mechanic
Is this a mechanical engine with pump/line & nozzle or electronic fuel injection? If it's got a rotary pump, I'd crack a line loose and see if you're getting delivery. If no fuel present at injector, I'd tie the fuel shut-off lever in the open position to physical end of travel. Do not trust the shut-off solenoid. Is it a 2 wire or 3?
mg2361
Pennsylvania
Equipment Mechanic
Mechanical injection. Under the valve cover unit pumps with their own injectors (which are not sold separately).
You said the fuel shutoff solenoid has voltage and is working, but does the fuel shutoff solenoid continue to have voltage while cranking?
Is there any smoke out the exhaust when cranking?
Brianr3989
colorado
I get black smoke out of the exhaust when cranking
Tyler d4c
Salix Pa
Boss has a skidloader that the rack sticks on it have to keep trying it will eventually start. The odd think is when it gets bad and you change the oil it gets better.
The little cover with one bolt you take off and see if it is stuck
Los07
Phoenix
What is the voltage at the fuel shutdown and what’s the last 3 of the serial number of the p185
mg2361
Pennsylvania
Equipment Mechanic
You said it shut down on its own and would not restart or did someone shut it down and it would not restart?
Is the air end putting an unnecessary load on the engine? Will it start with the air valve open? Has fuel supply pressure been checked? Return check valve been replaced?
NORTH CAROLINA
I have the start switch not a regular key if that helps.compressor has brand new harness two new relays new secu new fuel shut off solenoid all replaced prior to me getting to work on it TIA
