Hydraulic fluid change- ISO VG #46
Kevin Cohrs
Glencoe, MN
Looks like I need a high viscosity oil. Machine specs call for a viscosity index of 160 or higher. Believe the standard ISO 46 is rated close to 100. Not sure if it would really matter much...
skata
midwest
That's where it gets harder, to find fluids with a higher viscosity index. Which means it will perform better in colder weather.
I had hard time finding fluid for a genie lift. Ended up using dexron/mercon fluid, which is actully hydraulic fluid but red. And has a high viscosity index.
Kevin Cohrs
Glencoe, MN
So if you were to use a more standard hydraulic oil with a viscosity index of around 100, it basically would not perform well in extreme cold or heat? A 160 number or above must stay more consistent.
Ct Farmer
Connecticut
Amazing what a few minutes searching on the internet can do - Try the Texaco/Chevron Rando HD LVZ range of oils.
Specifically marketed as meeting VCE 1286.08 and 1286.0. and has passed both Volvo 2,000 and 5,000 hour Excavator Field Tests.
Data sheet attached - https://cglapps.chevron.com/sdspds/PDSDetailPage.aspx?docDataId=322447&docFormat=PDF
Rando HD is very good oil. Pretty much all we run. Not inexpensive at $650 a barrel last time we got a few but then replacing pumps isn’t cheap either. With oil sampling and use of a filter cart it lasts way beyond the recommended change interval. In the long run we figure using top of the line oil saves money.
I posted the details of the Texaco/Chevron product simply because it was the first one I came across.
At the time I was reasonably sure all the major lubricant companies would make something similar, I just couldn't be bothered to look any further.
The interesting thing to come out of this is apparently the oils that meet the Volvo "High VI" requirement are all ashless (zinc-free). So it appears that we can now add Volvo to the list of manufacturers that require ashless hydraulic oil in their excavator product line. Up to now Hitachi was pretty much the only name on that list.
I'm not saying a hydraulic oil with a zinc-based wear package can't be used. However it does not appear that a mineral oil with a zinc-based anti-wear package will meet Volvo's 160 Viscosity Index requirement, because they typically have a VI somewhere around 100. Therefore oils with a zinc-based anti-wear package do not meet the Volvo specification and by the letter of the law should not be used. On a machine with dealer support not using an oil that met Volvo's requirements would be a key factor, on an older machine possibly not so much.
What I am saying is that all the hydraulic oils meeting the Volvo requirement that have come out of the woodwork as a result of the OP's question are without exception zinc-free and synthetic, therefore IMHO it seems fair to assume that Volvo's specifications VCE 1286.08 and 1286.09 were written around ashlless synthetic oils.
Tenwheeler
Georgia
Add the JD mini X to that.
mg2361
Pennsylvania
Equipment Mechanic
I'd heard about some of the JD excavator product line requiring ashless hydraulic oil
"All" Deere excavators (since the metric designation) specify zinc free oil (Hitachi Super EX-46HN).
dewbee
Tennessee
I know this is old, but im going through the same issue right now and this fluid u posted about only has a vi of 107. Volvo states it needs to be 160 or more. I've called every bulk distributor within 100 miles of me and none of them carried over 100. Contacted the nearest volvo dealer and asked what the vi was and the didn't know. Asked for the pds on their fluid..they were clueless. I just want to see if theirs specs out at 160 or not.
