How to fill in potholes/road maintenance
LoaderMan94
Filling in potholes after a washout. What's the best way to go about doing it, without wasting mountains of material blanketing the whole roadway? Doing it the way I do it, I backblade a whole bucket over a bunch of potholes, but I waste a bunch covering the road and not the potholes and after a few passes of rock truck the holes pop back out just as bad as before I put the gravel.
Thanks guys,
For reference I'm on a Komatsu 475
JaredV
SW WA
Are they full of water? Water just makes the material mushy and squish out. But you can use the material to displace the water and come back a little later when the water has drained off the road. With a grader, if I can't cut them out, I'll fill them, wheel pack them, top them off and repeat our let trucks do the wheel packing. I'll ask trucks to aim for the holes to splash the water out before I get there but for whatever reason, they usually won't even though they have no problem driving through them to make them. Just have to stay on top of the holes until you get them fixed if you can't cut them out.
Or if I can cut a little, I'll top them off, wheel pack and get them mostly filled, then cut down a little to get below what I filled, but I still have to touch them up after a little traffic so they don't get away from me.
But getting the water out of them to start is a big help.
Do youu have teeth or a smooth cutting edge?
LoaderMan94
That sounds like a good idea! I will bring a full bucket of material, dump off to the side , cut the holes out , fill and wheel pack.
It makes sense to cut until you’re on good ground with the water gone , then build back up.
Thank you for your replies.
I struggled with potholes on the driveway at my property. Didn't want to dig up what was hard packed but filling them with road crush never lasted very long.
LoaderMan94
I ran into this problem again. There was a big set of ruts on a sharp comer and a muddy hole before the corner.
For the corner I back dragged a thick layer over the ruts cutting the middle hard top and wheel packing layer by layer until I was happy with the results
The mud hole . I back dragged the mud out the best I could and did the same thing I did for the corner brush out rocks and the last bit of mud that got mixed up in the material I brought.
Wheel packing layer by layer , the last layer I put on a bit extra and pressed it down with a weighted bucket before smoothing it out and wheel packing one more time. it looked a lot better than just covering it up and hoping for the best. The rock truck drivers were thanking me and saying it was a lot better as a was building it and they were rolling by.
Thanks a lot guys :):)
Cutting out the mess/water/mud is number 1
DDoug
Formerly digger doug
NW Pennsylvania
Thrash-A-Matic designer
I missed something. You fix potholes with a 475? I’m impressed. Good to have you on the HEF LoaderMan94.
“For reference I'm on a Komatsu 475”.
How can you even see 'em up in that cab ?
Just put the rippers down, take out all the concrete and start over ?
Camshawn
Langley BC
retired
One our driveway, I cut a small channel to drain the water. Once dry, I pack the pothole with deluxe road mulch (3/4 crush with crusher dust) and if there are more than a few, I bring the plate tamper down and hit them a few times. Seems to work reasonably well here. Getting rid of the water before there is much of a pot hole works the best.
I took care of a gravel equipment yard for time. We got busted asphalt from some milling jobs for free. I busted it up more with an excavator bucket and then spread with a grader. Pressed it in with a roller and it lasted pretty well. The dozers took their toll on it over about a year. No the asphalt contractors want you to pay for the stuff.
Here the local and state DOT want a credit back on all the millings per ton so that has pretty much eliminated the ability to get any millings unless it's a private job like a parking lot.
Our equipment yard started with a 1' layer of well hammered out limestone then topped with some dense grade base and 8910 (stone dust). Every 2-3 years we'll order 25 tons of 8910 and freshen it up. Hard as a freakin rock and drains very well.
The pile of stone is dense graded base which is our ALDOT 825B left over from a coffee shop project a few miles away.
Hardly ever have the heavier track machines on the yard but when we do during the winter for cleaning this combo of rock holds up great.
aussiechunda
australia
Looks good.
Would a snow pusher box help ?
What would help is magically making every other operator learn the niche skill of floor building with raw material so I dont have to fix them all the time, I have enough work keeping the face floors where I want them between my normal job of loading the crushing plant without having to worry about fixing the tip head. If I can achieve that then my job becomes twice as easy but those floors always end up downhill toward the hopper. The fact that our site uses loaders to do it is absurd in my opinion.1000001038.jpg
DDoug
NW Pennsylvania
What would help is magically making every other operator learn the niche skill of floor building with raw material so I dont have to fix them all the time, I have enough work keeping the face floors where I want them between my normal job of loading the crushing plant without having to worry about fixing the tip head. If I can achieve that then my job becomes twice as easy but those floors always end up downhill toward the hopper. The fact that our site uses loaders to do it is absurd in my opinion.View attachment 362017
Be that as it may...I still think a pusher box would be a good thing to keep sitting in a corner of the yard, you drive into it, and chain it on.
aussiechunda
australia
I think it would be ground into dust after a week of pushing concrete, ***** abrasive.
Teeth, heel plates and shrouds on my bucket last about a month.
Just need a dozer.
