Ncjetskier
My JCB 214 Series II (serial number slp214TCSE0435728) will not go into forward and reverse. All the fuses are good and occasionally you can get the backhoe to go into gear, but when you change from forward to reverse, it will not go - you loose both forward and reverse. I can feel the relays click when you change the forward and reverse lever, so I am guessing it may be the travel valve on top of the transmission.
- How do I access the valves?
-How do I test them to see if they are working?
Thanks for any help!!
