Hitachi 210 error codes
Kemper
Ontario
Hey! Have a hitachi 210lc that we are working on. We replaced the dpf and within 2 hours codes were present 10026-00 and 10029-00
Now I’ve told that the dpf and diff pressure sensors were to be programmed to read properly to perform the first burn properly. Just confirming. We have never ran into an issue where we had to program dpf serial in.
LACHAU
Saigon, Vietnam
Although I know this is the error code for the ZX210LC-5N, as Diesel Dave said, you must specify the model so we can better assist you.
And it's a real hassle with the ZX210-5N!
When you replace the DPF, you have to declare the serial number of the new dpf. To do that you need a special tool from Hitachi called MPDr. software and an adapter.
  • ZX210-5 10026 code troubleshooting.pdf
