anton_baydak
Hey I’m having weak power to all functions unless I’m dead heading some function. Just spent 6k for a new hydraulic pump with no fix. What is my problem. Thank you
@anton_baydak and @KOBE STEEL , check your messages.Do you by chance have access to a hydraulic schematic of your machine that you could post to me so that I can look in more detail at the the valve bank set up?
Info received. Its a big help, Thank you Dave.@anton_baydak and @KOBE STEEL , check your messages.
That is NOT your hydraulic pump......that is the swing transmission. Look for the main pump on the back of the engine.Hello All, excuse my ignorance but i presume this is the main hydraulic pump on my Hitachi EX120-5 , it has a dip stick on it and the oil is very low,
Thank you very much dave i will download that now. Here is the issue in a nutshell:-You can download a free copy of the EX120-5 Operators manual from the Deere bookstore.Link below,
https://www.johndeeretechinfo.com/search?p0=model&p0_v=Ex120-5&pattr=p0&page=0&sort= .
Your description of the machine performance issue is not very clear , please try again. What’s the machine serial # ?
Great idea, yes i will give that a go tomorrow, great suggestion. Cheers.Try running it with short hose from a clean 20L fuel pail
