The installation of the manual pump conversion kit seems to be working well on my 490E. I purchased the kit from SINOCMP (EX100-2 EX100-3 EX120-2 EX120-3 EX200-2 Conversion Kit for Hitachi Excavator with English Installation Instruction) which says it was manufactured in S.Korea. Payed $579 for the kit.
My only complaint about the kit is that it did not include the "T" fitting required, so I had to order that. It should be noted that the threads in the casting & blocks are BSPP. The casting also had some small defects that were visible in the bore (see photo).
I installed the kit with two "B" (4470236) and two "D" 4604530 shims which I interpreted as the baseline configuration from the chart. This allows you to add or remove shims based on the machines performance.
Installation was pretty straight forward once I had the proper T-fitting. I did have to remove the O-ring from the System Relief Valve and install it on the kits counter part since it wasn't supplied.
Once the kit was completely installed I added hydraulic fluid to the tank and blend air from the pump housing.
I have been running the machine with PVC unit unplugged. The machine runs better than I expected. The hydraulic functions react plenty fast, and heavy loading doesn't stall or bog the motor down at all.
I also installed a manual throttle cable and removed the old EC motor & sensor unit.
