Georgia Iron
- Joined
- May 6, 2012
- Messages
- 1,319
- Location
- USA - Georgia
- Occupation
- Concrete building slab and grading contractor
Hello all.
I currently have a 75xt case skid steer(7300 lbs) and mini ex (11,000 lbs). I want to get a larger machine to load dirt and clear land while the prices are cheap. Currently 953s loader seem to be going cheaper than in the past. 14k to 23k no cab.
I have been shown how to look at the idlers, rollers, pins, spockets, and basic under carriage. To check for wear.
My questions are?
1. I was told that LGP is the only type to buy?
2. What is a fair price for a machine now?
3. Does 4 or 6 cyclinder even matter. I drove a 4 and it would spin the tracks and not move when I pushed on a large enough pile. Which one burns less fuel?
4. How can you tell if the motor needs to be rebuilt?
5. What are signs that the hydrostat drive is going bad.
6. Is fluid in the belly pan normal for the older machine.
7. Any specific problems items to look out for.
8. Hauling. I also will need to get a dump truck and 20 ton trailer? Any advise on good older cheaper models?
9. Could i be getting into more than I bargin for? Might I be better off with the largest track skid steer?
Since I dont have a way to move it, and I dont have any work for it it yet it will be dead expense until I can get going with it. So far the skid steer seems to be the item that always goes to a concrete job or small grading job. I rip out a lot of concrete and have an old farm where I dump it. Wish I could crush it but dont have a crusher. I buy a lot of dirt and have to drive to get it for a single axle dump truck I have (F700) @ 25 per load (10 tons) I am always over loaded at the plant. But this truck will not be strong enough to haul the loader around.
I was thinking I could put the loader on the farm and dig up a big dirt pile to have dirt to sell to my customers and bury all the old concrete. Right now I have about 18 loads of concrete I need to deal with, almost 400,000 pounds
But the loader will not be able to dump it lightly into the back of my dump truck. So that is a major draw back. I am running out of spots to dump it. Yes i could spend a day with the ex and skid steer and get rid of the concrete which involves me moving both machines out to the farm. The machines are keep about 7 miles away. I use the dump without a trailer cause it does not have a way to hook them on. I use an F250 (prefered way) or F550 to move my machines now.
Getting dirt with my skid steer is too slow. It takes about 12 - 14 bucket loads to fill my truck and I feal like I am wearing it out trying to dig up dirt. Around here you can take a dump load of concrete to the crusher and pay $65.00 per load to dump it and you can buy it back crushed for $11.00 per ton. So if I deal with it myself every load will save me $65.00. And every load of dirt I dig up and sell could be worth $25.00.
I am not sure how many loads of dirt you can get out of a gallon of fuel in the 953. Here in georgia we have mostly red clay.
Plus it would just be nice to own a 31,000 pd loader. I have always wanted a loader.
Thanks For any and all advise.
My questions are?
