Coaldust
- Joined
- May 9, 2011
- Messages
- 6,048
- Location
- Subarctic Backwoods Trailer Park
- Occupation
- Big trucks is what I know. HAZMAT is what I tow.
John, it’s fun to look back on all those crazy things we did.
Speaking of battery cases, I’ve had good luck fixing leaks & cracks with a polypropylene welding stick & a propane torch.
Speaking of burned out, lead battery posts: I still have a pair of post molds.
I’ve had a pretty good success rate with the old baking soda distilled water and new sulfuric battery acid! If you want to try it I’ll give you the procedure
For the effort, time and risk I think I'd much rather pull some cash out of my wallet and buy a new battery.John C has nailed the problems very well in post #9. There's a major design difference between regular starter batteries and deep cycle batteries. Regular starter batteries have thin plates because they're designed to produce short sharp bursts of high electrical energy output.
Deep cycle batteries have thick plates because they're designed to produce steady levels of far lower electrical energy, over a much longer period of time.
I tried the epsom salts trick maybe 50 years ago with dubious results. Shake up the battery, empty the electrolyte out into a bucket, treat, treat the empty battery with epsom salts solution. Empty the epsom salts solution, flush the battery out with clean water (twice). Let the electrolyte settle, then pour the clean electrolyte back into the battery and top up with fresh electrolyte. Some batteries would recover for a while, most didn't improve a great deal. I think totally degraded plates were likely the common problem.
Dead cells are usually the result of broken-off plates caused by vibration, or by buildup in the bottom of the cell reaching the plates and shorting them out. Good design batteries have plenty of clearance from the bottom of the plates to the bottom of the cell and they also have the bottom of the plates secured. Plates that just "hang" in the cell, attached by the top only are very prone to vibration breakage.
Today, I use a battery desulfator. A unit called "Infinitum". I use it as a stand-alone desulfator, with a simple 4 amp trickle charger. The U.S. military use these, so they must have shown some benefits.
I usually never try to recondition a battery that is under about 11V. They're generally well and truly past saving if showing under 11V. But above that voltage, I simply hook up the Infinitum desulfator and leave the battery on charge for a day or two.
The dead batteries generally recover well using this unit. At this point I've achieved a battery life of 10 yrs and 4 mths from one battery, and 10 yrs and 9 mths from another. Both were Yuasa batteries and I consider Yuasa batteries to be premium grade batteries. I've got another battery in my tractor crane that I don't know the age of, because it came with the crane, but I'm sure its around 10 yrs old. It still goes well, and I give it the Infinitum "treatment" regularly.
There's a guy with a YouTube video who is slamming the Infinitum desulfator. I believe he's probably got other electrical problems that have caused his desulfator to fail. My Infinitum unit works just fine, and has done for around 8 years. The green light on the desulfator only comes on once the battery voltage reaches a satisfactory level.
You'll find a lot of websites booming up desulfators. Watch out for the Amazon shill websites who post glowing reviews of desulfators, where the site promptly redirects you to Amazon, to buy one.
My Infinitum desulfator cost me AU$44 about 2014. I think it was a pretty good investment, it's paid for itself well and truly. I always have about 6 or 8 spare batteries laying around the shop, and I keep them "tuned up" with the desulfator.For the effort, time and risk I think I'd much rather pull some cash out of my wallet and buy a new battery.
have 372 batteries to take care of, at $115.92 each that's $43,122.24.
refer starters 108 comes to $38,664.00
tractor starters 65 comes to $24,100.00
so roughly $105,000 just in those parts, expensive to operate these days.
