Diggaman
I think my American 185 excavator is a Hitachi UH07 grey machine. Did Hitachi stamp model and serial #s on these old machines some place else on machine. There is a American model plate under the boom. Looks like there was a plate on inside the door. Its gone. The front idler has UH07 casted on the shaft bearing blocks.
Thanks
That is a one very interesting photo.
Might i suggest you do a Google image search on following Hitachi Model "UH081" or as it was orginally called in Japan a UH07-5.
As far as Serial No. goes there was only one place for it on Japanese Domestic Market Machines & as you have quite rightly pointed out ,it was attached to the inside of the door.
On Export Market machines S/no. was stamped in a brass plate attached between the two boom lift cylinders.
If you let me know what S/no. you have found looks like , might be able to see if it lines up with what Hitachi used.
Heres a little bit of back ground info if your interested.
These (UH081's / UH07-5's) were produced from about 1980/1981 through to about the end of 1983.
Should be powered by Hino naturally aspirated straight 6. Engine Model EL100.
Kawasaki pumps, Swing Motor & i think control valves as well.
Hitachi made their own final drives for this model excavatior as well.
Parts for these lovely old bits of gear are pretty hard to get through Hitachi , Especially track gear.
