I've got an older Geith coupler QH110 serial # 227604 that's on a Volvo ec330b lc trackhoe. I'm having trouble finding parts and not 100% positive what parts need to be replaced.
The engaging plate goes around the rear pin on the bucket but if i set the bucket on the ground and lightly curl out the engaging plate will come unhooked from the rear bucket pin. There seems to be decent play where the engaging plate connects to the rod on the hyd cylinder. I don't think the rod is bypassing the seals inside the cylinder. The hooks where the front pin sits does have some wear. I believe its a mixture of a lot of things slightly worn that's allowing enough play for the rear pin to release.
Not sure if I'm better off trying to rebuild this coupler (if i can even find parts) or just take it all off and attach the bucket directly to the excavator. I don't use any other attachments. Only problem with doing that, the pins on the bucket will need to be line bored out to fit directly to the trackhoe and even then I think I'll have to install new pin bosses for everything to fit properly.
I guess my main question is what would be the cheapest way to get this fixed so I can get back to work? Thanks.
