Howdy all! I am looking for some advice on a Galion 503G, it's used at a museum I help out at. It was plowing some snow yesterday, and suddenly failed to proceed. Clutch works fine, and can shift through all gears, but some slipping and grinding noises from the transmission. I pull off the rear trans cover to see the ring gear and found a damaged ring and pinion gear, and some pieces of both in the transmission bottom. This machine does have a manual, with a hand written note of:
"PN: 70077951, Ring and Pinion shaft and gears are the same as used in Allis Chalmers crawlers "D" and "DD" anbd Fiat Allis grader "M65""
Is this correct? Any ideas on where to find new gears?!
I also have some photos of the transmission casting below too:
