Willie B
Your truck needs a good pressure washing, a cut off disc on a hand held grinder, then oil bath of something penetrating. I'd choose New Hampshire brand. It'll be ten years before the frame starts to fold.
NH oil creeps like crazy and doesn't drip.Your truck needs a good pressure washing, a cut off disc on a hand held grinder, then oil bath of something penetrating. I'd choose New Hampshire brand. It'll be ten years before the frame starts to fold.
Self tapping screws and old license plates has always been the farmers choice for floor pan repair.
Well okay-Sigh. Farmers . . .
I saw a Pete a while back with a laminate wood floor.
But seriously, aside from finding a 30 year old rust free cab to steal floor repair pieces from, your going to be stuck fabbing your own. Cut squares and rectangles and weld the seams, or a good man with a pan or finger brake.
but if you don't have enough licenses plates handy you could use sheet metal like you have one the plenum of your furnace, find a wholesaleThis was for sale Zero Rust, set of sticks, 8V-71 with heavy front axle on walking beam.
IIRC $2,000 no title. IIRC it only had 50,000 miles on it.
I hear road signs work pretty good, too.Self tapping screws and old license plates has always been the farmers choice for floor pan repair.
GuiltyI hear road signs work pretty good, too.
Yes, I went from a 3 HP cheap snow blower at age 9, I cleared the neighborhood.Trust me on this.
If you have a hole in your floor, it can really come in handy.
Drainage for ice and snow.
If you drop something, you won’t even have to open the door to pick it up.
If you get pulled over for open container, you can just pour it on the ground.
You can see the ground, to know when you drive off pavement.
If you have an exhaust leak, you can really hear it.
When your needing to take a leak, just hold it down.
The best, if you run out of gas, you can Fred Flinstone it back home.
I grew up plowing with a 62 +or- Scout. Dad had rigged up a keg for a gas tank. You could get stupid drunk and plow and if you needed to puke, from seeing the ground rushing by, back and forth, you just leaned over and heaved.
That thing was a piece of crap but it plowed better than the 9n, out in the cold and snow, had to replace the bungee cord holding the door closed once in a while and the manual wipers sucked.
