Ford 555D hydraulic cylinders
NH575E
North, FL
Retired Machinist
Good luck! I'm about to tackle the boom on my 575E. I found stock on the obsolete kit for it so with a whole bunch of luck I will have one rebuild go my way.
materthegreater
VT
Many thanks @Swetz and @NH575E! The kit from CEA was correct, all the seals were perfect match to the originals (minus the deterioration of course!).
I've installed the gland on the rod but have not reinstalled the piston and bolt yet. What torque spec do you guys use, or do you just let the rattle gun go until it won't go any tighter? Red threadlocker on the bolt threads?
NH575E
North, FL
Retired Machinist
I use blue loctite and hammer the bolt with a 1" air gun till the compressor cycles back on then let it build and do it again. I have an undersize compressor though. So far I haven't had one come loose.
materthegreater
VT
This one had red on the threads when I took it apart, but it also came off with just a 1/2" air impact
rumblecloud
Michigan
Living the dream...:]
This is what mine looked like prior to reassembly:
I had to have mine professionally removed. Admittedly I did not apply heat or really "get after it" as this was my first crack at a cylinder re-seal adventure and I did not want to damage anything. I did do the re-assembly much the same way as @NH575E. Torque specs for these cylinder pistons are unreal and I doubt guys like us (normal, relatively sane), have the necessary equipment to achieve those numbers.
Good luck on yours.
NH575E
North, FL
Retired Machinist
Those of us with older machines can't really go by what things look like when we take them apart. No telling how many times they have been apart and how many people like me that ignore some specifications and do things our way have been in there.
The question of Loctite type and torque specs comes up from time to time so I went to the E series manual seeking answers.
Here are the rod and gland torques listed in the E series New Holland manual.
Here is the list of Loctite numbers and types.
My manual calls for the 262/271 High Strength Red for piston bolts and glands. I will continue using 242 Blue on the bolts and anti seize on the glands.
So there you have it. Figure out how or if you want to do it by the book or follow your own path.
materthegreater
VT
Good luck on yours.
I didn't use heat either.
I don't know what New Holland calls for, but this one has a class 10.9 M24-2.00 piston bolt which has a standard torque spec of a little over 800 ft-lbs. Being a D Series it may be a little bit different than the numbers in the chart that NH575E posted.
Swetz
NJ/PA
Electric & Gas Company
I use the blue Loctite on the bolt. I have a powerful 1" drive that zaps them off and on. I do not check torque...good..n...tighten..,LOL
cosmaar1
Ohio
Holy Smokes NH. I hadn’t went looking for the torque specs for the crowd cylinder I’m rebuilding now. I thought at the most it was 700-800 lbs. Looks like my battery 3/4 Milwaukee impact is going to have a feast!
Swetz
NJ/PA
Well, both the loader bucket cylinder and the steering cylinder are reassembled and seem to be working fine with no leaks so far. Thanks for all the advice!
Thanks for the update. I am glad it all worked out!
