Plan B
I have a customer who had me replace a head gasket on his tractor. So i had the head resurfaced but not magnafluxed and replaced head gasket and torqued bolts to 105 ft lbs. from inside to ends three times to make sure they were all torqued properly. Well he called today and said it was still blowing water out of the cooling system. Any ideas on what it could be ? I know it could have a crack in the head or in the block but would anything else cause it to blow water out? Im gonna go check it out later , Im thinking about checking to make sure the water pump is working properly?
