Alternator conversion
Thought this might be of interest to anyone who has had a generator fail. My problem was fairly simple, the amp meter stopped showing any charge with the engine running. Bit of diagnostic work showed the generator to be the culprit. I won't go into details on this as I'm by no means an expert on generators. The principles are straightforward and I'd reckon anyone with electrical knowledge should be able to figure it out. In my instance a multi-meter told the story. It cost me $20 from our local re-winders to get it confirmed that my armature was shorting to ground and the only solution was to re-wind. The problem in my instance was that the generator bushes were completely flogged out and the armature was hitting the sides. The damage can be seen in the image.
Initially I considered re-winding and sticking with the original generator. Generators are old technology but I figured this one had lasted over forty years and was a good solid bit of equipment. Initial estimate (part of the $20) put the repair cost between $400 and $600 to completely rewind and replace bushes. I might have proceeded had I not stopped and thought about the generator control box. This also contains windings and was also forty plus years old. Bitter experience with Murphy's law told me that the moment I rewound the generator, the control box would go belly up and cost another $500. Regretfully I decided to ditch the original arrangement and update.:deadhorse
For me there was no decision as to what to use for a replacement. I've had a good run out of Bosch alternators over the years so I went straight for a Bosch 24V universal. The original generator installation is quite a neat system. There's a bracket that attaches to the machine and has the twin pulley drive (greaseable) on the front. The generator itself sits on this bracket and is held on by a single broad strap. Drive is through a basic coupling.
Because I liked this arrangement I initially looked at getting a bare shaft alternator and simply transplanting the coupling onto the front of the alternator. Both the coupling and an alternator shaft were 17mm. After a bit of head scratching I abandoned this idea as I'd have had to quite radically modify the alternator and/or the bracket. Consequently I went for a BXU2456A alternator that comes with a double B section pulley on it. I obtained mine via the internet and it arrived within a few days. Prices vary but you should get change out of $300 (mid 2012)
My installation was fairly basic and brutal. The original bracket had two legs that sat either side of a boss attached to one of the radiator support arms and had a 12mm bolt through them. The alternator had a single mounting leg with a 10mm hole through it. I drilled the hole in the alternator leg out to 12mm, cut the support boss back and welded a threaded lug onto the support arm. I cut the support boss back with a 5" angle grinder without removing it from the machine. I carefully calculated where to cut it, did the deed, then lined the alternator up with a straight edge.
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Something wrong somewhere. Back to the grinder! I ended up with 30mm of the boss left. I then sat the alternator in place with a 12mm bolt through, carefully lined up the pulleys and measured up the front tab. I can't give measurements as I didn't take any. A bit of WeetBix box and a pair of scissors were the design tools
![Alt 3.jpg Alt 3.jpg](https://www.heavyequipmentforums.com/data/attachments/81/81967-0eb2e046c3a3865bdd6eaea657a362f4.jpg)
The front tab was duly cut out of a bit of 10mm flat bar (grinder again), drilled and tapped to 12mm. I then offered it up, screwed the bolt in, checked the pulley alignment and tacked in place. Removed the alternator and welded properly. I only welded across the front so that the weld would pull the tab forward, allowing easy alternator installation. It pulls back when the bolt (100mm x 12mm ) is tightened.
This got the bottom support sorted. I then attacked the top, adjustable bracket. For some strange reason the stud that this bracket attaches to goes right through to engine oil. I had a lot of trouble with mine and had to take it right out. I put it back in with some hydraulic sealant on the thread. Anyway the bracket modification was fairly simple. I put in the vice and bent a dogleg into it, then welded on a short piece of 1" flat bar. I actually used a bit of stainless but that was only because it was handy. I drilled the 8mm hole for the alternator centrally.
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I should have offset it as I then had to clearance the bracket where the alternator bulges. See image.
Main hassle on this job was the need to change the belts. Sounds easy but the hydraulic pump drives off the front of the crank. I had to disconnect the flange on the front pulley, take the radiator guard off, then back off the pump mounting bolts as far as I could without dropping the pump off. This just allowed room for the belts to slide through. The original belts were 52". Actually one was, the other was longer and unlabelled. Who'd only replace one belt!:Banghead Anyway, one was too tight for the alternator. If they'd been good I might have persisted but they weren't so I replaced with two BX53's. I got busy with the grinder again and did a bit of clearance work where the belts pass over the support arm. They weren't touching but were close enough that I figured that they would, once the belts stretched a bit.
That covers the mechanical side of the job. I'll cover the rest in the next post and another five images.
