Hi
So I recently revealed th swivel joint on my cat 315c because machine seemed to be losing hydraulic power when it warmed up. Mechanic said th seals were likely bad, 6200 hrs, however they looked fine. Anyway it didn't seem to make much difference and now I've lost turning power. Started out on th right track mainly forward but now both tracks either direction. Sometimes when still cold a certain direction will suddenly kick in and have normal turning power but when warmed up good it basically never will. When putting the swivel back together I had to put a lot of pressure on it to push it back together. Is that normal did they give me th wrong seals? Th machine di run fine for maybe 10 hrs after the swivel was reinstalled.
