RobMonk
I have a Cat 311B and the last couple of times I was using it, loads that would normally do nothing to the machine are bogging the engine down to the point where a couple of times it actually stalled. The last time I was using it I was frigging around with it a bit and I thought I had cured the problem but about 3 hours into the day it started acting up again. It sounds like a lack of fuel issue because it seems to be intermittent. I can lift a small rock and almost stall it and then lift a huge rock and it does nothing. I am working on the theory of water in the fuel or a bad filter but I decided I would run it by the forum to see if anyone else had this problem in the past.
