Jmckinstrie
Hi all. I’m at my limits. Lost compression at some point in machine. Thought is was just a workout injection pump. Had that rebuilt. Still no start. Full rebuild with oem Isuzu parts. Liners kit. Bearings. Cam. Head work. You name it. Assemble it in my garage and fired it up on a cradle I built on a pallet. Didn’t run it long maybe 1 min. But it fired right up. Installed in machine. Bleed fuel lines again. Nothing. Turns over good fresh batteries. Just bellows white smoke. What the chance the hydro pump is causing an issue to cause a no start? The engine is 100% mechanical. Unfortunately no local shops will service or help and I’m usually that guy people call with questions. Please help with what ever you may think of. This machine is for personal use to build a home. I’m desperate to get my family moved. Thanks guys.
