Ed's 77 Terex 72-41
56wrench
alberta
these are all the reasons i suggested the possibility of patching up what you have. it may be easier and faster
  • Like
Reactions: mks
mountainguyed67
Fresno, California, USA
I would only do that if I converted it to a turbo in the process. This is the heaviest model machine with this engine, making it the worst horsepower to weight ratio. Plus it’s at elevation, 5,300 feet.
If it had a problem developing with one cylinder would certainly affect it's power output. I think other posters are trying to help you avoid opening a big can of worms. A proper rebuild should restore the engine to full power. There may be other ways to increase the power a little without requiring a turbo.
56wrench
alberta
but you will not be happy if you cobble together an unknown engine combination and it or the trans grenades. with more power than designed for, you may find a weak link somewhere else in the drivetrain. on a machine that is getting harder to get parts for that is a chance i personally would not take. just pointing that out. ultimately its your call
Agree with 56, not knowing how much safety margin the original components were built with I would be concerned that boosting the power would shorten the life of those pieces. Remember even if the original design had a 15% safety factor in the design that was when ever thing was new!
If a nice fresh engine is still not going to be where you need power wise maybe you are trying to do too big of a job with too small a machine?
Like they used to say where I worked "You can't put 10 tons of **** in a 5 ton truck and expect it to last!"
As for not getting answers to some of those questions, like I said due to the fact that there are many different ways to spec a 4-71 to try to make definite statements about the adapting one to replace another can be something of a mine field especially without having them sitting next to each other. Also due to the age of both these engine the chance some one has made a change to them since that tag was put on at the factory also adds to the problem.
Just the fact that on most of those engines the tag is on the valve cover adds a layer of unknowns, is the valve cover even the right one for the engine it is on?
OP was saying that the machine is up in the hills @ 5300ft ASL.
Anyone have an approximate idea what is the altitude rating of a 4-71 before the fuel system has to start getting tweaked.?
I have no idea but in my experience most big yellow engines are generally good for at least 5,000ft before derating. In many cases significantly more than that.
Birken Vogt
Charter Member
Grass Valley, Ca
Non-turbo usually they lose power fast at that elevation. However, I think if that is the case, they will show a lot of black smoke if you get into it. If there is not black smoke then power is simply being limited by fuel quantity injected (injector PN in DD case).
mountainguyed67
You can see the smoke here.
Bluox
WA state
Here is all I got , If your motor do have N 65 injectors it should be a 150 HP. motor.
It's pulling that bad piston I bet its only putting out around 100 HP.
If You lucked out so far you may not have ruined the block.
At your alt. the derate should only be 3-6 HP. depending on the temp.
If the motor you are looking at is indeed a fire pump it may be 250 HP. + and like the marine engines it is heat exchanger cooled ,you missed the loader keel cooler part.
Since your loader has a radiator it won't cool much over a 150 HP.
I truly think your best bet would be over haul your motor .
But its your zoo and your monkeys so carry on.
Good luck
Bob
mountainguyed67
Terex calls it a 160.
I don’t understand this. Alt = alternator?
I didn’t miss it, that’s one of my questions that didn’t get answered. I asked if it was a different block, and could I still bolt the water pump to it.
So it would need a bigger radiator.
