Ed's 77 Terex 72-41
Rustyfender
Ontario, Canada
Equipment operator
Thanks for the offer, but being as there is no hurry , I would imagine we will hear from someone who knows.
Rustyfender
Ontario, Canada
Equipment operator
OI finally found some information on. This and it seems simple. Enough, pully is on a straight non tapered hub with a woodruff key, seems itshould pull off and damper iebolted to crank with 6 " special bolts"
Rustyfender
Ontario, Canada
Equipment operator
I went and looked at that engine today ( 300 miles on my truck I will not get back) but I left the engine there as it was going to Be to much of a nightmare to get everything hooked correctly.
mountainguyed67
Fresno, California, USA
I was working on the tilt cylinder yesterday. These are the old parts, I didn’t get a fresh picture. The seal in the middle is too wide to go in there, one side wants to stay raised. I since measured the groove width at .246”, and the seal width at .271”. That’s 25 thousandths interference. Doh! I should have checked the parts people’s work. I can check the local place I usually go to tomorrow. In the beginning they said they stock it, but were out of stock. I can see if they restocked, and take my calipers with me. I need to go there anyways to get o rings for the hose fittings.
What are you compressing it with? These will require Squeezing to get them into the barrel. I used Aluminum Flashing pieces and hose clamps.
There are actualy Stuffer tapered tools to install these and the Chamfer at the end of the barrel I have not ever had luck getting Gland Seals past.
